You can configure virtual routing and forwarding (VRF) for the tenant. You can specify the name of VRF and the associated tenant, target VPN community, Route Target and Route Distinguisher, Local ASN, IPv4 and IPv6 static BFD routes, IPv4 and IPv6 static next hop routes, number of load sharing paths, redistribute type, whether resilient hashing is on SLX devices, and the routing type.
efa tenant vrf create [ --name vrf-name | --tenant tenant-name | --rt-type { both | import | export }| --rt value |--local-asn local-asn | --ipv4-static-route-bfd route | --ipv6-static-route-bfd route | --ipv4-static-route-next-hop route | --ipv6-static-route-next-hop route
| --max-path unit |--redistribute { static | connected} | --rh-maxpath { 8 | 16 | 64 | 128 } --max-path {1-128} | --rh-ecmp-enable= {true | false } | --graceful-restart-enable= {true | false } | --routing-type { distributed |centralized }|--help ]
For more information on syntax and command examples, see the ExtremeCloud Orchestrator Command Reference, 3.6.0 .(efa:root)root@node-2:~# efa tenant vrf create --tenant tenant11 --name blue11 --local-asn 65001 --rt-type import --rt 100:100 --rt-type export --rt 100:100 --rt-type import --rt 200:200 --rt-type export --rt 200:200 --rt-type import --rt 300:300 --rt-type export --rt 400:400 --max-path 50 --redistribute connected --redistribute static --ipv4-static-route-next-hop 10.20.246.6,192.168.0.0/24,10.10.10.1,5 --ipv4-static-route-next-hop 10.20.246.5,192.168.10.0/24,10.10.10.5,5 --ipv6-static-route-next-hop 10.20.246.6,2020:20::1/128,3001::2,6 --ipv6-static-route-next-hop 10.20.246.5,2020:30::1/128,3001::3,5 --ipv6-static-route-bfd 10.20.246.6,3001::3,3001::1,100,200,5 --ipv6-static-route-bfd 10.20.246.6,3001::2,3001::1 --ipv6-static-route-bfd 10.20.246.6,3001::4,3001::1,100,300,6 --ipv4-static-route-bfd 10.20.246.5,10.10.10.1,10.10.10.254,200,300,6 --ipv4-static-route-bfd 10.20.246.6,10.10.10.5,10.10.10.252 --rh-ecmp-enable --rh-max-path 16 --graceful-restart-enable --routing-type distributed
Vrf created successfully.
--- Time Elapsed: 772.62533ms ---
(efa:root)root@node-2:~# efa tenant vrf show --name blue11 --tenant tenant11 --detail
Tenant : tenant11
Routing Type : distributed
Centralized Routers :
Redistribute : connected,static
Max Path : 50
Local Asn : 65001
L3VNI :
EVPN IRB BD :
EVPN IRB VE :
BR VNI :
BR BD :
BR VE :
RH Max Path : 16
Enable RH ECMP : true
Enable Graceful Restart : true
Route Target : import 100:100
: export 100:100
: import 200:200
: export 200:200
: import 300:300
: export 400:400
Static Route : Switch-IP->Network,Nexthop-IP[Route-Distance], ...
: 10.20.246.6->192.168.0.0/24,10.10.10.1[5] 2020:20::1/128,3001::2[6]
: 10.20.246.5->192.168.10.0/24,10.10.10.5[5] 2020:30::1/128,3001::3[5]
Static Route BFD : Switch-IP->[DestIP,SourceIP][Interval,Min-Rx,Multiplier], ...
: 10.20.246.5->10.10.10.1,10.10.10.254[200,300,6]
: 10.20.246.6->10.10.10.5,10.10.10.252 3001::3,3001::1[100,200,5] 3001::2,3001::1 3001::4,3001::1[100,300,6]
VRF Type :
State : vrf-create
Dev State : not-provisioned
App State : cfg-ready
--- Time Elapsed: 47.564929ms ---
(efa:root)root@node-2:~# efa tenant epg create --name epg1 --tenant tenant11 --port 10.20.246.5[0/1],10.20.246.6[0/1] --vrf blue11 --switchport-mode trunk --ctag-range 2001 --anycast-ip 2001:10.10.11.1/24
EndpointGroup created successfully.
--- Time Elapsed: 12.400157552s ---
On Device1:
10.20.246.5SLX# show running-config vrf vrf blue11 rd 172.31.254.211:1 resilient-hash ecmp enable resilient-hash max-path 16 evpn irb ve 8192 address-family ipv4 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ip route static bfd 10.10.10.1 10.10.10.254 interval 200 min-rx 300 multiplier 6 ip route 192.168.10.0/24 10.10.10.5 distance 5 ! address-family ipv6 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ipv6 route 2020:30::1/128 3001::3 distance 5 ! ! |
On Device2:
10.20.246.6SLX# show running-config vrf vrf blue11 rd 172.31.254.152:1 resilient-hash ecmp enable resilient-hash max-path 16 evpn irb ve 8192 address-family ipv4 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ip route static bfd 10.10.10.5 10.10.10.252 ip route 192.168.0.0/24 10.10.10.1 distance 5 ! address-family ipv6 unicast route-target export 100:100 evpn route-target export 200:200 evpn route-target export 400:400 evpn route-target import 100:100 evpn route-target import 200:200 evpn route-target import 300:300 evpn ipv6 route static bfd 3001::2 3001::1 ipv6 route static bfd 3001::3 3001::1 interval 100 min-rx 200 multiplier 5 ipv6 route static bfd 3001::4 3001::1 interval 100 min-rx 300 multiplier 6 ipv6 route 2020:20::1/128 3001::2 distance 6 ! ! |
(efa:extreme)extreme@node-1:~$ efa tenant vrf create --name red13 --tenant tenant21 --max-path 50 --redistribute connected --redistribute static --local-asn 65002 --ipv4-static-route-next-hop 10.20.216.104,192.168.0.0/24,10.10.10.1,5 --ipv4-static-route-next-hop 10.20.216.104,192.168.10.0/24,10.10.10.5,5 --ipv6-static-route-next-hop 10.20.216.104,2020:20::1/128,3001::2,6 --ipv6-static-route-next-hop 10.20.216.104,2020:30::1/128,3001::3,5 --ipv6-static-route-bfd 10.20.216.104,3001::3,3001::1,100,200,5 --ipv6-static-route-bfd 10.20.216.104,3001::2,3001::1 --ipv6-static-route-bfd 10.20.216.104,3001::4,3001::1,100,300,6 --ipv4-static-route-bfd 10.20.216.104,10.10.10.1,10.10.10.254,200,300,6 --ipv4-static-route-bfd 10.20.216.104,10.10.10.5,10.10.10.252 --rh-max-path 64 --routing-type centralized --centralized-router 10.20.216.103,10.20.216.104 Vrf created successfully. --- Time Elapsed: 726.425268ms ---
